bbaker2001
May 03, 2016Explorer
ram 3500 oil change
2015 Ram 3500 diesel has 4800 miles 7 months new. dealer said I need to do oil change now. 2nd dealer says not yet, when should I computer says 62 left
Cummins12V98 wrote:FishOnOne wrote:Cummins12V98 wrote:bbaker2001 wrote:
so if Blackstone gives OK, does that mean you can go linger than 6 months. will you have to ship it to them each time, and what is the cost
The Chrysler guys said if I had oil analysis to back up the oil was good that going the full 15K will be fine with going over the 6mo. They said if you don't have any documentation and consistently go over 6 mo and have an oil related claim they most likely deny warranty.
I think the analysis and cost with the TBN result is around $27. They do recognize Blackstock as a reputable oil analyzer.
I did call them today and I will be taking the sample directly to them hopefully tomorrow.
So what condemnation levels on this Blackstone oil analysis do these FCA guys claim is acceptable (i.e. fuel percent, insolubles, TBN, flashpoint, soot, TAN, viscosity, etc...etc..)?
Bottom line if they don't back their condemnation levels in writing, then their statement is not even worth passing along heresay rumors and is downright irresponsible.
Blackstone tells you if your oil is suitable for continued use or not. They will tell you how much longer you should ben able to go if the oil still has life.
For those that don't know. When you send in a sample you tell them what engine you have, year, length of time or hours on oil, oil quantity added if any. Plus other info, the bottom line is it's a very engine specific analysis. They also want to know what oil and maybe filter used.
