work2much
Jul 20, 2017Explorer
Nautique200 wrote:
I am considering ordering another Ram with the Air Suspension. In the manual it states:
Protection Strategy
In order to “protect” the air suspension system, the vehicle will disable load leveling as required (suspension over- loaded, battery charge low, etc.). Load leveling will auto- matically resume as soon as system operation requirements are met. See your authorized dealer if system does not resume.
I'm likely going to go with the air suspension anyways and hope that when I overload the truck past 14K it will take it.
You will be fine. We are 1,000 over GVWR (note the manual doesn't state GVWR but suspension overloaded). I read that if there is too much weight the truck won't inflate the airbags making it obvious that you have loaded too far.
We are under axle and tires. I think this is more just boiler plate language for the guy why tries to load 4 pallets of concrete. In any case been there and doing that for thousands of miles on rough roads. No issues. Ordering a host mammoth in a month or so.
