hellfirehydra
Jun 15, 2017Explorer
rjstractor wrote:Perrysburg Dodgeboy wrote:
Also called them out on the fact that the Ram was a bumper pull towing a Ford with a water tote in the bed but the GMC was a fifth wheel with two water totes on the trailer at each end. They are becoming just another bunch of clowns getting free trucks to beat on with mindless clowns eating their dribble up.
Both the Chevy and the Ram were right up at their axle and towing limits. The Ram had the extra weight in the bed, but its trailer was lighter than the gooseneck pulled by the Chevy. Both trucks were predictably wheezy at elevation and seemed to perform similarly, times aside. I suspect the gas Ford would perform about the same, although it seems to take a person with no real brand loyalties to acknowledge that. The one test I watched where the Ford posted a faster time it was towing considerably less weight to that is not a valid comparison.
Again, you have to take this one test for what it is and it isn't fair to any of them to compare the tests with completely different trailers/trims/weights.
I suspect that towing the same trailers they'd all be within a minute of each other which makes it all about buyer's preference. I personally prefer the Ford 6.2L then the Ram 6.4L in that order for gas engines. I drive a Ram diesel because I preferred the Cummins over the other diesel options.
I would definitely like to see them do back to back runs with all the gas trucks for a good fair comparison of engines/transmissions.
