alexleblanc
Mar 21, 2017Explorer
Perrysburg Dodgeboy wrote:goducks10 wrote:
Wow. Ford spanked em all.
LMAO OK until you get to the towing and weight section, you know the work part. What it showed is they ALL are just about the same until again you get to the working part of the testing. Then Ram and Chevy both spank the Ferd.
Carry on Don
Not really the case when they are all equipped with the highest gear ratio, put the 4.30 gears in the Ford and the ratings come up to pretty much the same as the others. More a case of how each test truck was optioned, in real life when optioned properly, the big three are very similar ratings wise.
What's more surprising is the fact that the Nissan is there, it is in no was close to being on the same playing field as the others, it belongs in a test with the F150 HD and the GM with their heavier payload model. More of a 5/8 ton class really.
