wgriswold's avatar
wgriswold
Ram Battery Low Voltage Warning
When towing I am getting a Battery Low Voltage warning from my 2016 Ram truck. It went away after several starts when the trailer was disconnected.
It may be caused by the truck being set up for charging its AGM batteries and then also charging the trailer's lead acid batteries. If this is correct then I would expect other Ram owners to have had the same problem.
So has anyone else had this problem?
