Me Again wrote:
B.O. Plenty wrote:
Interesting how people quote problems that occurred on 6.0 Ford diesels, Dodges with 4 spd transmissions, injector problems in Duramax diesels a couple of engine generations ago. The current crop of diesel trucks are pretty good. They have all experienced a learning curve and have become pretty good as a result. Buy what you like there isn't much difference from one to another anymore.
B.O.
That is why I said 2015+ RAM's have most of the bugs worked out, and then along came Troy!!!!!
Chris
Its good you said most, the emissions on the 2013-15 Ram Cummins are a problem, and well documented, and not just an isolated issue as some here like to paint.
When you see the recall on your 2015, then YOU will know, or you get a DEF warning and CEL, and off to the dealer for the TSB, or worse.
