falconman515's avatar
falconman515
Range Hood and Power/Water Wall Meter just stopped working?
So I had my trailer all good to go and everything worked on the the last trip out a month or two ago ... going camping this weekend, picked up the trailer from storage, turned everything on to make sure all was well and out of nowhere the range hood light/fan will not come on and also the wall mounted water and power meter doesn't work (the one where you press the button for 12v/fresh/black water and it gives you lights to tell you what your levels are).
The lights, radio, water pump switch (that's actually located on the 12v/water meter) all works.
I pulled the fuses all looks fine there ... kicked the breaker and turned it back on and nothing ... tried disconnecting shore power and plugging in my truck (since i have the batteries in the garage charging) to see if it would do anything different running straight 12v and Still Nothing!?!?!?!
Any suggestions on what this may be?
I notice now to that the LP alarm beeps every time I unplug the shore power and beeps a whole bunch of times when I turn it back on ... kinda like it's resetting .... nothing funny other then the fact that it never did that before is all.
I am not hugely worried about the 12v/water meter (though I for sure want it working if at all possible) but the wife really needs the over the range light and fan for cooking.
Any help here would be greatly appreciated guys! :)
Thanks so much.
-Chris
  • It must be a simple power or connection issue. I was thinking maybe part of the rig has a wire connection at the battery terminals and that may have loosened or not be connected when the batteries were removed. A beeping LP alarm usually means a lack of 12v power. It's also possible that the converter is not supplying power to the different 12v circuits and that the lights and various 12v devices are getting just enough power from the truck connection. I would definitely replace the batteries and see what happens. Do you have a meter so that you can troubleshoot the electrical system, should that be necessary?
  • westend wrote:
    Sounds like you have some loose connections. Have you tried putting the batteries back in place?
    No I have them in the garage charging ... I will be putting them back on the trailer tomorrow night.
    Hopefully that may fix the issue ... I assumed disconnecting the shore power and running of the trucks 12v would have basically been the same thing but maybe the batteries need to be there for some reason.
    Though I bought the trailer and never had batteries for it till a week before I went camping the first time and all it ran on was shore power and I never had an issue before at all, so I doubt has anything to do with the batteries not being connected.
    Just pulled the meter panel and everything looks good.
    Just don;t know how something happened between taking a block away to store it for 1-1/2 months then picking it up and bringing it back to my house another block ... and ll the sudden out of the blue the range hood and battery/water meter stops working ... cause it all worked Perfect before I stored it.
    This damn trailer is like a money pit and I'm done putting money into it ... guess if it doesn't work anymore ... well it doesn't work anymore.
    Was just hoping maybe someone may have an idea what it may be or have seen something weird like this before.
  • Sounds like you have some loose connections. Have you tried putting the batteries back in place?
