fj12ryder wrote:
Krusty wrote:
Would be interesting to compare the diameter of axle tubes and the thickness of the material that they are composed of as well
Or maybe even the frames those axles are mounted on?
Would be interesting to compare. Gut says the new axle is just as stout as the old one.
Frame I’m sure is stronger on a new half ton.
You guys get it. My point is the 1/2 ton trucks have gotten stronger and yet rated lower, in general.
But I would argue for the brakes on the old one, just a bit.
Of course a new HD has better braking, but those big ole drums in back do Work!
Mine still has the load sensing valve, disconnected. But when I turn it to full flow, that old ass truck stops FAST!
