rjstractor wrote:
NC Hauler wrote:
OK, I'm confused...He stated he's NOT over his GVWR (gross vehicle weight), but IS over his RAWR by 400#
Did anyone not catch this...If he is over his RAWR he's WAAYYY over his GVWR..unless he meant he wasn't over the trucks GCWR...but again, I get the impression that he IS over his trucks RAWR, but because his tires will handle more weight, he should be ok
Not necessarily over on his GVWR. The GVWR on a newer SRW F350 is 11,500. So, if he is 400 over on RAW, is he is running less than 4K on his front axle he could be less than GVWR. Granted, that is pretty light on the front end. I myself am surprised no one asked where the kingpin placement is in relation to the centerline of the rear axle. If it's too far back he could be unloading the front axle, and if that's the case moving it forward to just ahead of the rear axle could solve all his weight problems.
OK, you may be on to something and I should have thought it out a bit more. He could be over RAWR and not be over GVWR..my bad....(been a long last 3 day's13 hr day's at work:))...
BUT, that would bother me to think I'm overloading my RAWR by 400#..doesn't sound safe. You also may be on to something about his hitch mounting..if not in the correct position, could wreck havoc on pin weight putting more on the axle.
Thanks for helping me get back on track.....
