Mike_Tassinari
Oct 04, 2021Explorer
Hello Moonlitsouls.
Lets face it, going off grid is all about battery storage capability - solar panels and how to charge ones battery bank.
This is my set up,,,
Ford Truck - 2002 Ford F350 7.3 diesel
Truck was ordered with the single alternator.
Second independent Alternator - 200 amps
Twin Deka group 31 flooded deep cycle battery's hanging from the trucks frame rails. All wiring is of 1/0 gauge welding wire. (fine strand)
Lance R/V - Twin Deka group 31 flooded deep cycle battery's
Total of 4 solar panels for a whopping 470 watts of charging. The solar panels are fixed and do not move.
Also for ease of wiring, the 2 factory solar panels have one thirty amp charge controller and the 2 Kyocera panels that I added also have their own 30 amp controller
Also the Lance R/V has been totally re wired with 1/0 welding cable.
For connectors between the Truck & RV I used 175 amp Anderson Connectors
All Battery's are wired in parallel configuration with the positive wire of the R/V on battery #1 positive post and the R/V negative with on battery #4 of the negative post. This way all battery are equally in play and draw down together and charge up together.
Besides the usual R/V electrical usage, I keep an ARB compressor freezer in the back of my truck that also draws off my Battery Bank. It stays on all the time and have had this ARB in the truck for over 2 years now.
Lastly I have a 2000 watt pure sine invertor located in the R/V and is wired with 3 - double pole, double throw relays so I can take 3 120V circuits off the Lance 120 volt system and with a flick of a switch swap these circuits to the Inverter.
I can go up to 3 cloudy days with no sun and my battery bank will be in the 11.8 to 12.0 range.
My latest test was my R/V was parked in from of my house for 3 weeks with no shore power and admit to have no more than 2 cloudy/rainy days at any given time and my battery bank never ever dropped below 12.2 amps.
The best charging feature for me is that independent 200 amp alternator and its exciter circuit. I have seen over 50 amps of power going into my battery bank when driving down the road.
Yes the solar is great but with 3 stage controller limiting me to 70 percent bulk charge then 20% absorption charge then the final 10% float charge, when your battery bank is down 50 percent or so, you need something faster to charge those 4 battery's
Lithium battery's do not work for me as I do too much winter camping and if you are the owner of Lithium battery's you know what the cold does to them.
Bottom line:
Four - 115 amp Deka flooded battery's
Four - Solar panels with a total of 470 watts
Zero electrical issues.
Mike Tassinari
Bottom line:
Mike Tassinari
44,030 PostsLatest Activity: Jan 20, 2025
