pianotuna
Aug 02, 2016Nomad III
Re: Battery charging
Hi,
What converter do you have? How many amp-hours of battery bank do you have? If there are multiple batteries are they wired in a balanced manner?
Using a smart charger may sometimes be better than the stock converter, and at other times, worse. If you have one already, go ahead and try it. There is no need to disconnect the converter from the battery bank. Simply disconnect it from the 120 volt power source.
