White_Whale
Sep 15, 2016Explorer
kohldad wrote:
Gointhisaway has a 10.4 on a 2008 Ram and had the issue. Torkllift sends an angle bracket (3 pieces each side) that bolts in the existing tie down bolts and moves the connection point rearward so the torklift clears the rear fender. Very easy install except for the drilling the bracket to match the existing pattern since the material is hardened. Just so happens I will see her within 24hrs and should be able to snap a picture if you would like.
You could also make your own with a piece of 1/4" angle 8' long.
Since your Bigfoot is new, you should check with them as some manufacturers were adjusting for the new fender design and moving the rear point rearward. So the new design may save you some headache.
You can consider yourself lucky. My sister didn't find out about the problem until she had driven 2000 miles to pick up her camper from a dealership. She had to wait around a couple of days for it to get shipped and then another couple days for them to get it drilled and installed.
Edit: Forgot to tell you the 10.4 is a very nice rig with a great layout for two. Only big issue my sister has had was they ran a water line against the outside skin which caused it to freeze on a winter outing. Once she moved it and put a little insulation between it and the wall, shes has been well pleased.
The dealer in Oregon we are buying the 2016 10.4 from measured it yesterday and the rear tiedown eyelet is 91 1/2 inches from the front of the camper. The link I provided in the second post said if you are over 90 inches you should be good to go.
I certainly hope so because, like your Sister, we won't know until we try and mount it up at that dealer. Hopefully if there is an issue the materials will be readily available to to remedy the situation since i have alerted him to this topic.
I'd love to know where that water line was located exactly so I can be sure we will not have a duplicate issue.
Cheers
Jim
P.S> "Just so happens I will see her within 24hrs and should be able to snap a picture if you would like."
That would be great if you could. What year Bigfoot 10.4 was it?
44,056 PostsLatest Activity: Jan 22, 2026
