Bedlam
May 13, 2019Moderator
Re: Chevrolet Silverado Medium Duty
You need 3.75' from the deck to the top of the cab to have sufficient TC cab over clearance since most current model TC's are designed with 4' of clearance under the cab over. You should have measured cab and frame rail heights too. If it sits lower than a Ford or Ram, you may be able to lift the camper to clear the cab yet still be under legal height.
