dkhender
Jan 23, 2008Explorer
Using the ideas I've gleaned from here and other forums, I'm in the process of adding two cameras. A back-up camera on the TV - I've purchased a lisc-plate mount camera for that, and also found since I had factory Navigation system, I purchased the adapter to add that camera view directly into my NAV system - that way when I put vehicle in reverse the NAV screen automatically switches to the rear TV camera. Also adding a camera to the TT - as I will only use this while towing (obviously) for this I purchased the camera set-up with a rear camera and will view that through a rear-view mirror (similar set-up to what stugpanzer did). That way when not towing, I just remove "add-on" mirror with camera viewer. Working now to determine best mounting method for camera on TT. Will post pics when complete.
44,029 PostsLatest Activity: Jan 13, 2025
