Kejsj30
Mar 03, 2008Explorer
jeeptp75 wrote:
I am just wondering how are people attaching things to the walls of their trailers. Expecially the flat panel tv's. I would love to do that but worried about it pulling out of the wall. What do you need to do special to make sure what you attach stays attached :)
Take a piece of plywood large enough to span two wall studs on your wall (either use nice looking wood piece with routered edges or cover with the same wall covering as your trailer). Mount your TVs mounting bracket to the piece of plywood (you can through bolt in to the plywood). Now you can mount the plywood to your wall...............should give you the added support you are looking for.
44,030 PostsLatest Activity: Jan 21, 2025
