takeakidcamping
Jul 28, 2008Explorer
I bought a 6" piece of PVC pipe 5ft.long for my sewer hose and instead of using brackets to mount it up under my camper,I got some string and laid it across the top and bottom of the pipe from one end to the other,taped it with duct tape and then painted the string with spray paint then removed the string.That gave me a line on the top and bottom.I drilled 5/16 holes down the line 6" apart and on the opposite side I drilled 1/2" holes.The 1/2" holes are enough clearance to use the adapter on the fitting of a cordless drill.Have the side of the pipe with the 1/2"holes down toward the ground.Using the 5/16 self taping screws that hold my underpinning on,I mounted the pipe down the frame and you do not have any brackets to worry about.
44,056 PostsLatest Activity: Jun 25, 2013
