Frank_Mehaffey
Feb 18, 2019Explorer
Where to begin.........Wheel size in snow does make a difference when you have 2wd. Probably with a 4wd too. You get more penetration to the pavement with a smaller footprint. I found that out with my original 99' F250. Put a wider tire on, thinking that might help in the snow, and had worse traction for the drive wheels than with the original tires. I put 4-5 tube sand bags in my bed in the winter.
The OP, me, is certainly open to hearing what everybody posts. I just don't have to agree with the nay sayers say about 17" wheels. I have driven about 400,000 miles with 17" tires in the last 20 years, and if you drive conservatively, which I do, you will not have a blowout unless you have a crappy tire. Would it be better to have a 12-14 ply for potholes, yup, can't argue there. When I have my next truck in 2 years, I will be getting a 350, for the 4wd, and it will probably have 18" on it. I won't refuse them!
I have an aggressive tread with my winters, with the rears studded. But the aggressive tread is pretty much what the tires were when I bought all 3 of my F250's.
At 80 lbs., my 17" rear tires have never felt mushy or with noticeable sway, and visibly have never seemed overloaded. I check tire temperature about once a day when I have the camper on, and it has seemed fine.
Thanks for all the input about tire sizing and especially about comparing brands. I am NOT dangerously overloading my tires, I am at or just under the load limit when I bring EVERYTHING, clubs, bikes, 1/2 water tank, and as long as I check pressure, replace when the tread wears or sides crack, don't drive like I am on a track, I will stick with the 17", which have all worked well for me.
The mike is dropped!
44,026 PostsLatest Activity: Mar 01, 2025
