serpa4
Jul 03, 2014Explorer
Hello everyone, this is my second post on the TC forum. My previous one was getting info on how to make my F450 with a 5th wheel bed work for a TC. Thanks to folks here I think I got that figured out.
Now I need help in trying to choose the right TC for my needs. I have a lot of experience with 5th wheels but zero with TCs. I have a 2004 F450 with a heavy duty bed and airbags so I think I can handle most any TC but I need help with a TC education. The closest dealer is over 200 miles from me so I'm hoping to get basics from you guys.
I want a TC mainly for solo use with my dog and my Harley. I'm planning a 4-6 week trip out west pulling a trailer with my bike and I will also use it locally for similar outings. I will continue to use the Fiver when my DW wants to go and she or my grandkids may join me on occasion in the TC. So here are some newbie questions I need help with.
1. What are the positives and negatives to a side entrance? Do all side entrance TC extend well beyond the truck bed?
I'm sure all side entrance will extend well beyond the bed due to the door. I'd like a side entrance next. I'd like a larger awning that can come with a side entrance. Side is more conventional like other RVs. Also, nice when you park in circles with others. Side entrance will likely have more stairs to get in and out for entry.
2. What are the positives and negatives of a wet bath vs a dry bath. Based on reading here the wet bath allows more space for other area with the downside being you have to dry it manually after each use. Anything else?
I've had both. Only dry bath for me. Hate the water on the walls, sink, floor, etc. Drying doesn't take too long, but is a pain.
3. I plan to tow a trailer with a motorcycle, about 2K. How should that impact my choice and do I need any additional hardware for that?
No, you can tow what ever you want with the proper hitch and hitch extension. Torklift super hitch or reese titan.
4. Do most folks have a built in generator? Currently I have a Honda 2000 to charge fiver batteries. Will it run the AC in a TC?
I don't use a generator much, but will never be without one. Completely optional depending on who you talk to. A 2000 honda will generally power a 9000btu ac at sea level. Bigger ac or higher, it's a gamble. Went to Florida last week, no ac=no trip. EVen in Walmart parking lot in route, ac is a must.
5. Is backing under the TC and hooking up easily done by yourself? I've never seen this done.
Backing up is always by myself. No issues.
6. How much clearance (inches) between your truck fenders and the TC jacks is normal? I think with my bed I will have about 1.5" on either side.
1.5 on each side is pretty narrow. I like about 2.5-3 inches.
7. What are good tie downs and how much should I expect to pay for them and installation.
Frame mounted are best for large side entry TC. Small popup can be with bed mounted.
8. What's the difference in mileage and handling with a TC wight of 4K vs 5K? Current pin weight is about 3K with my fiver. I would think my mpg would be better since I want have the huge fiver drag, is that correct?
I've had both 4K and 5K. If your truck is rated for it, suspension wise, not much difference. Pulling hills, 1000 lbs is nothing. Wind resistance and mpg will be the same. Wind drag is about frontal area and speed unless you hit the hills then a TC will be less weight. With my 33' toyhauler to a large TC didn't result in much gain in MPG.
9. Lastly, since I don't want to start a brand war. I want a quality unit that I hopefully will not have to drive hundreds of miles to return for repairs. After reading much here it sounds like Arctic Fox and Lance are among the better quality units. What is the major differences between the two brands other than AF is heavier?
That is a can of worms. lance sells more than anyone, but personally have never liked the quality (fit/finish) of lance. AF is usually a pretty good quality of TC. I've had two and although very heavy, very good quality TC. I have a Host TC and it's pretty good quality, but the AF was better.
Thank you for your help. I know this is kind of long.
44,056 PostsLatest Activity: Dec 27, 2025
