FensterRV wrote:
Well hello Family of Nine
Few random things.
Consider prying the wood off the back of the TV in the bunkhouse ( which I havent done yet) so you can hook up a DVD player and video games via HDMI to that TV- ( Rainy days )
Don't pry the wood off. There are 4 set screws (one in each corner). Remove those screws and then remove the mount set screw. The TV will lift off the mount no problem.
I put a quick connect plug on the end of the cable to make it a bit easier and while traveling I use a tennis ball I cut to relieve the pressure jammed between the tv and the frame it sets in.
