FensterRV wrote:
DRX
Can you elaborate on the mount set screw? I have 4 screws on the first larger panel but then I dont remember seeing this . Been a while though-
Thanks.
Fenster,
Once you get the wood panel off there should be another wood panel that the tv mount is mounted to. There is a square hole cut out of it. If you look through the cut out, which will show you the back side of the tv mount, you will see a set screw the holds the tv on the mount. Once you remove the tv mount set screw you can slide the tv off the mount and get to the back connections. I never put the set screw back in the mount. Once i slide the tv on the mount I take a tennis ball that I have cut a slit in and wedge it between the tv and the frame.
Hope that helps. Once you get that panel off it will make sense.
