coobrey wrote:
Just FYI
I have a 31bhpr and during a complete downpour here we had leaking in the main slide. I wasn't parked completely level, the driver side was a bit higher. But the issue wasn't necessarily just that as the bunkhouse slide did not leak at all. The issue was the seal on the top of the main slide. There are two rubber flaps that did not lay out correctly and were stuck in the position I would think they would be in when the slide was out. I took a long stick when the slide was in and repositioned the rubber flaps to their correct position and all was well after that.
Looks like slide toppers next season
Had the exact same issue on our 28RLPR, but it only happened once. Looked at the inside rubber flap and the rubber had pulled thru the screws,wasn't down flat and there wasn't many screws holding the flap to the sidewall. Added washers to the screws and put more screws along the way.Looks like laziness on the factory end !!! No issues since but I always check it now !!
