kirklandsc wrote:
Hi everyone,
I am new to the forum and buying my first travel trailer. I have tent camped for years and my grandparents had TT's and I have been recently with friends who have a pop-up.
My wife and I have been searching for about a year now and we finally decided to go with a 2013 Keystone Premier 31BHPR. We looked at so many and it came down to a 2012 Palomino T-291, 2013 Solaire 317 BHSK, 2013 Keystone Outback (with queen bed slider in back) and the 31BHPR.
My tow rig is a 2011 CC Nissan Titan SV 4x4. I have Bilstein Shocks, Nitto Terra Grappler e rated tires, Magnaflow muffler, and Volant cold air intake. I am getting a programmer this week. I normally tow a 25' deck boat about every weekend from spring to fall. My boat is right around 6500lbs loaded with water, fuel and gear, and the truck tows it great.
I think I should be fine towing this camper, as it will be mainly used spring through fall at our lake property. I will only be towing around 20 miles round trip on fairly flat roads. But I plan to venture out to some campgrounds later this year.
Any advice and tips for a newbie would be appreciated and I look forward to being a part of this forum.
You'll get a lot of feedback on what type of truck it takes to pull this trailer. I think most replies will be on the conservative side, not that there's anything wrong with that.
I have the exact same trailer you speak of in your post. It's about 6300 lbs unloaded. I tow it with a 2005 F-150 (2x4, SuperCrew, 5.4L, 3.73 rear end, Equal-i-zer WD hitch (1000 lb distribution bars) throughout Florida. There are times I wish I had more power, however it is a stable tow at 60-65 MPH yielding about 8-9 MPG. My main concern is payload. With my trucks' payload of 1600 lbs and a hitch weight of about 900 lbs (including the actual weight of the hitch), I have very little margin for extras in the truck after loading the the four of us (550 lbs). You'll have to make sure your WD hitch is set up properly.
If you have experience towing a 6500 lb boat with no problems, and plan on towing it the distance and terrain you speak of, you won't have any major problems. There will be times you wish you had more power, but with an easy-does-it attitude, you'll have no problem.
