coobrey wrote:
I have a 31bhpr, and it really squats the rear end of my 2005 Excursion. It drops the ball 3 3/4" inches when the trailer is attached (without my equalizer brand distribution hitch attached). Even with the distribution hitch attached I have quite the squat in the rear.
Just yesterday I swapped out the stock Excursion springs for those that were on a F350 (c-code, 3000lb each). I STILL get a 3 3/4" drop when I attach the trailer. Now the F350 springs gave me an 2 1/4" increase to start, but it still drops a lot. I haven't hooked it up with the equalizer hitch yet so I am hopeful that some change will have come from the spring swap.
Is anyone else seeing this with their trailer? I don't even have the water tank 1/2 full right now. Thanks for any info.
That sounds completely normal to me, I would think it would come back up a couple inches after you attach WD bars. I don't think you needed to swap the springs, I would have seen what it looks like after you get the WD all set up and dialed in first.
