gilligansail123
Feb 12, 2022Explorer
HI supercharged111, I'm looking for a wiring diagram because I want to change from lead acid to lithium batteries in order to do that I will have to change the charge controllers.
I also want to add an inverter so I can use 110v without running my generator or being plugged in. In order to do that I will have to change the charge controllers, and incorporate the an inverter into the system. I will be adding the 110v outlets to the inverter circuit as well as the shore power and generator.
So actually its more than just adding batteries.
Thanks Gilligan
Thanks Gilligan
