Re: Need help with battery drain at ELX-30 converter
For a replacement converter, the WFCO series have been popular with the A-Frame crowd for replacing the Elixirs. The WFCO have 3 stage battery chargers which is better for the batteries life. Pick one that fits your mounting area best.
http://www.bestconverter.com/8700-Series_c_83.html
As for parasitic drain, if you have a propane leak detector, it will bypass the fuse panel as will the emergency brake disconnect switch for safety purposes.
No RepliesBe the first to reply
