Sounds like you’ve already made up your mind and are just looking for validation. Oil viscosity begins to reduce the minute it’s manufactured. Here’s a comment from the McNally Institute:
Oil that has not been changed for a long time will begin to gel or solidify in an engine, eventually turning into sludge once it has been exposed to the environment. This will result in oil starvation in crankshafts, bearings, camshafts, and other valve train components if the oil is not able to reach all parts of the engine.
Others have said to go by the manufacturers recommendations, which is also good advice.
At the end of the day you can ignore all these comments and do whatever you want because it’s your vehicle and you are the one who has to drive and repair or replace it. Most of us who replace our oil more frequently due so as preventative maintenance because we want our vehicles to last longer without mechanical issues, but you do you. Good luck.
