Talisman61
May 10, 2018Explorer
westend wrote:
For the few times I've used them, the tank grommets work well. They never leaked. Your bulkhead fitting is OK but you'll need to make sure that you can tighten that gasket against the tank. I'd probably try to use some sealer if using that bulkhead fitting.
Good luck!
Have you ever used tank grommets going in the side of a tank though?
44,056 PostsLatest Activity: May 04, 2014
