afidel
Aug 20, 2022Explorer II
Re: Schwintech slide system
Most of the horror stories are from folks who has the system horribly misapplied by the engineers at the manufacturer. Schwintech had very specific design guidence about where their system should be used, some manufacturers used it in slides that were twice as long and 4x as heavy as specified. Your single dinette slide should most likely be fine. Lube it as called for in the manual, don't stop with the slide partway in or out, keep the bulb seals treated and it should give you many years of service.
