Goldencrazy
Jan 29, 2015Explorer
Schwintech slide leak
I have one slide that moves a tiny bit and most of the time it makes no noise. It just started with a noise that makes me think the rubber seal on the front is rubbing and making the rubber to something sound. It is not the motor that sometime requires lube and can squeak. It really seems to be the seals. Winnebago Sightseer 35 G. Anyone else have this issue and did you lubricate it and successfully stop it? I also tried using a brace to stop the movement but the movement is so subtle the brace made no difference. Any ideas?
