ejd43
Jun 14, 2020Explorer
Lynnmor wrote:
Replacing the valve on the toilet will fix it. I would connect a hose to the supply line before connecting to the new valve and run the water full blast to flush the line.
You may have the winterizing valve on the water heater not fully open. If there are check valves in either the inlet or outlet of the water heater, they may be jammed with debris.
I did try taking the check valve off on the outlet side but it was being a bugger to get loose and I didn’t have all the proper tools with me. Should I just replace the check valve totally?
44,056 PostsLatest Activity: Aug 03, 2021
