jayboogee
Jul 08, 2015Explorer
T3rry1 wrote:
is there an option for the sway control on this setup? i didn't think there was since it was theoretically supposed to be built in, that's why i got this one to start with.
Looking at the stock photo you posted of your WD hitch, yes, there is, you can see to the right and left of your hitch ball, there are two more holes, where the smaller, friction sway control ball would screw into, then the sway control would hook onto an identical ball that would be drilled in horizontally to the side of the trailer frame. Exactly how i have it set up. Might be a cheap resolution for you.
The one piece of advice I can give when using friction sway control, is once you get off the highway, pull over and disengage/losen the sway control, otherwise it makes a loud metalic grinding noise during those tight secondary road turns! Freaked me out at first. Hah
44,025 PostsLatest Activity: Feb 18, 2025
