Hondavalk wrote:
Scubydg wrote:
So we had the trailer loaded the same way for both the tacoma and the tundra. And there was considerable difference in sway..Could I have too much weight loaded forward and that cause sway?
Sway is caused by a lack of tongue weight, not to much. If your tow vehicle is overloaded on the back axle it will cause your steering to become to light, but not cause trailer sway. I pull a 450lb utility trailer thats all over the road if I don't add tongue weight. My TT is 7,800lbs loaded and tows fine behind my Tundra. I did switch switch out the P rated tires with E rated LT tires though.
Actually a light steering axle will "feel" like sway, and have the same consequences. The trailer will wag back and forth. That is what a WDH does. It returns lost weight to the steering, axle, which returns control to the driver.
