Scubydg wrote:
So we had the trailer loaded the same way for both the tacoma and the tundra. And there was considerable difference in sway..Could I have too much weight loaded forward and that cause sway?
the "sway" may not have been the trailer wagging, but improper WD hitch setup. To little weight transfer to the front of the TV, front of TV rises, camber is affected and the front of the TV wanders all over the place. I've had two friends who with smaller TV complained about sway and when we went over the setup, what I described was exactly the problem. Very little weight transfer, fair amount of tongue weight way to much front end rise resulting it to light a front end and lots of camber on the front. Once adjusted properly with minimal front end rise, they were flat out amazed and the difference. Very very stable setup.
