Ben, even these guys are screwed up.
Hotrod wrote:
Similarly, if the gear ratio is 3.08:1, then the output torque will be 308 lb-ft. It’s easy to see that the lower 4.10:1 gears put more power to the ground than the higher 3.08:1 gears. Keep in mind that the engine’s power has not changed but that the available torque to the tires has.
Even the writer of this article is trying to use torque and power interchangeably which you can't do. Then at the last he gets is straight and correct.
It's no wonder people are confused. :R
