BenK wrote:
Sign of the times...semantics or the evolution/slang usage in our language...
Just like when pointed out the difference between the original usage
vs todays usage of 'motor' vs 'engine'
Am going to start referring to an ICE's starter as a 'starter engine'...doesn't
sound right does it?...well at least to my earballs... :B
Lost to too many is that HP is derived from torque...if there is
no torque...there can be *NO* horsepower...
Or that there can be 1,000,000 ft/lbs of torque, but no HP...yet... :?
So, torque is power, HP is power...POWER is torque or HP in today's usage... :S
Turtle n Peeps wrote:
Ben, even these guys are screwed up.
Hotrod wrote:
Similarly, if the gear ratio is 3.08:1, then the output torque will be 308 lb-ft. It’s easy to see that the lower 4.10:1 gears put more power to the ground than the higher 3.08:1 gears. Keep in mind that the engine’s power has not changed but that the available torque to the tires has.
Even the writer of this article is trying to use torque and power interchangeably which you can't do. Then at the last he gets is straight and correct.
It's no wonder people are confused. :R
I am having trouble understanding your argument. It sounds like you are saying that people don't understand what they are talking about when they use terms like torque and power therefore the true meaning of torque and power is lost
It's kind of like because people say "I could care less what you think" instead of properly saying "I couldn't care less what you think" we should understand what the person means and instead of correcting the error make both phrases mean the same thing
