Turtle n Peeps wrote:
I must have said it here 20 times:
Gears don't make power! In fact, if you want to get technical about it, they make slightly less power.
I have also said this numerous times: Torque is not power. You can have 1,000 ft/lbs of torque of and 0 power out put.
Put a set of 3.00 in you truck and chassis dyno it. Then put a set of 4.56's in and dyno it. Want to bet me a $100 bucks which gear set puts out the most power to the rear wheels? :B
To much work for you? Fine, just dyno your truck in 1st gear and then dyno your truck in 4th gear or whatever gear is closest to a 1 to 1 ratio. What puts out the most power to the rear wheels?
You're right on, gears don't make power. . .gears multiply torque. However, under certain conditions pertaining to pulling an RV things aren't always that simple.
Say the OP hooks up his new truck to his 20,000 lb RV and hits his first hill, a 6% grade. It can be determined that 312 Hp are required to be delivered to the rear axle in order for the truck to maintain 50 mph climbing the grade. It can also be determined that at 50 mph with 32" tall tires the rear axle will be turning 525 rpm. In order to have a hope of getting 312 hp to the rear axle while turning it 525 rpm the truck will necessarily be in 3rd gear. With 4.10 gears the engine will be running 2885 rpm. With 3.73 gears the engine would be running 2624 rpm. The engine will definitely be able to make more torque at x2624 rpm than it can at 2885. Without a torque curve for the Cummins it is impossible to know for sure but it looks as if the 4.10 equipped truck could deliver the 312 hp to the rear axle the 3.73 equipped truck could as well. So in this situation both trucks flat out would be capable of delivering exactly the same power and torque to the rear axle.
Edit: to further develop this argument. Consider if the truck could only pull the hill at 48.5 mph. The 4.10 equipped truck would have its full 385 hp available @2800 engine rpm. The 3.73 equipped truck would be able to deliver less power. Steepen the hill to the point where the 3.73 runs flat out in 2nd gear at 2800 rpm and it will be able to deliver more power to the rear axle.
