Cherokee & Wolf Pups have a FRAME mounted rear basket fold down carrier. There are frame hinge brackets and the basket arms rest on the bumper. My Wolf Pup has one. The spare tire is mounted to it with a welded bracket. They claim you can use the carrier lowered with the spare on it. Me, I worry about ground clearance. Rack capacity is either 150 or 200# WITHOUT my 40# spare tire. I'd like to modify the spare tire carrier bracket to be removable but replaceable for clearance. I'll likely cut it off this summer for clearance IF I want to use the carrier AFTER I lift the axle.
