RobWNY's avatar
RobWNY
Rear View Safety Backup Camera System Questions
I bought the 2 camera with 7" monitor backup system from Rear View Safety. I will be adding one camera to the back of my truck to aid in the hitching up task and the other will be on the back of my camper to see what's behind me when going down the highway. I will have to attach the power lead to the fuse panel somewhere so I bought a Fuse Tap to do this. What amp rating fuse should I make the attachment? I can't find anything in the documentation or on their website that indicates how many amps the system uses. Also, I want to attach the power lead to a switched power source. Which accessory fuse in my TV would be best to attach the fuse tap to? Also, I don't want to attach it as their directions say by combining the blue wire with the red power wire to have the camera turn on only when in reverse because I think that eliminates my ability to use the 2nd camera on the camper when going down the road. Is that correct? Thanks in advance for your input.
