ScottG
Feb 25, 2018Nomad
If the front windows work then there is power available for the rears.
Tap your rear window lockout button a bunch of times real hard and see if the rear windows work for a little while. If they do, you have an issue with cold (and cracked) solder joints in the switch assembly. This was very common.
You can replace the switch assy for about $100 or if you're good with a solder iron, simply rework them.
44,027 PostsLatest Activity: Mar 05, 2025
