westend
Sep 09, 2015Explorer
swimmer_spe wrote:Wherever there was a problem with the structure supporting the roof, I used home made jacking posts (2x4 tee) to support the roof trusses.westend wrote:
I rebuilt my walls from the inside. Look at the restoration thread in my signature line, "The Cowboy/Hilton".
I like what you did. However, i am not doing a complete gut job. Only the bad section is where I plan to rebuild.
Did you replace the wall joists? How did you do it without the roof coming down?
My trailer had bad wall sections where the wall studs, the wall top plate, and the rafter ends were missing or rotten. By supporting the ceiling rafters with the aforementioned jacking posts, I was able to remove sections and rebuild the wall framing. I've done this stuff for years but anybody that can build a dog house can do it.
My number one piece of advice would be to keep everything straight, level, and plumb while proceeding. Some folks that try this get a bad fit for the siding at the end of it and develop spots where there are gaps, especially where walls intersect or at the corners.
44,066 PostsLatest Activity: May 13, 2026
