Led_67
Jun 11, 2013Explorer
travelnutz wrote:
More Plastic and composite junk failing and/or not being nearly as strong in service or as good as steel or the metal it had replaced. No secret that it's nearly always the consumer/customer that takes in the posterior one way or another and still has to replace or repair at their expense as always. I'm so sick of it!!!!
What ever happened to: "Do it right the first time" ? Then there'd likely not even be the need for a second time!
How's this?
Special of the day!
Want to buy a new fancy expensive RV built on a fabulous "NEW" Lippert made plastic frame? Our experts verified that's the strongest frame we have ever tested!
On second thought, it may be as good as the many frames they already had made using cheap thin metal and then very poorly welding it that have been constantly breaking for years now. No problem today. You can just regard the RV as a "throw away" and come see your "NEW" RV again with the improved plastic frame that even has our revolutionary never before used composite braces guaranteed for 1 year from date of manufacture. Firm!
Enjoy our outstanding Lippert exclusive peace of mind warranty:
If breakage should occur within that first year of warranty coverage, Lippert will re-glue or epoxy the frame back together at our option if authorized and delivered to our factory at blah blah blah.
Some exclusions apply:
RV having traveled on unpaved approved by Lippert Corp roads are exempt.
Having traveled in rainy weather or on wet roads are exempt.
If frames were not inspected monthly per the stated warranty conditions at a Lippert approved inspection center and all documents in triplicate having been filled out and signed in front of a Notary and note that the original must arrive within 3 business days, from the date of inspection, at the Lippert Warranty Office at the address given below, the RV will be permanently exempted.
Thank You for buying Lippert Frames of Quality and Distinction. Our future is in your hands and your future is in ours!
Very well said my good man lol
44,071 PostsLatest Activity: Aug 30, 2026
