JoeChiOhki's avatar
JoeChiOhki
Explorer II
Jun 10, 2013
RECALL - Lite Cylinder Company, ALL composite Cylinders
I'm forwarding this along, because I know there's been members here in the past that loved those see-thru fiberglass cylinders. Time to go back to steel ;).
We have recently learned that The Light Cylinder Company, in cooperation with the U.S. Department of Transportation Pipeline and Hazardous Materials Safety Administration (PHMSA), is recalling all LPG composite cylinders.
PHMSA has issued an “Emergency Recall Order” for all LPG composite cylinders manufactured by The Lite Cylinder Company as per the following Emergency Order No. 2013-002. The recall notice specifically identifies those cylinders manufactured under DOT-SP 14562 (and DOT-SP 13957 as authorized therein), DOT-SP 13105, any cylinder re-qualified under H706, and any cylinders manufactured under M5729. All cylinder sizes are involved in this recall: 10#, 20#, 25# and 33#
The emergency order is based on an investigation of Lite Cylinder’s operations and production history that revealed probable violations and unsafe conditions and practices that PHMSA determined present an imminent hazard to the public safety.
Under no circumstances should a cylinder affected by this emergency recall order be filled, refilled, or used for the transportation of hazardous materials.
PMSA advises customers to follow the guidelines provided by Light Cylinder Company below regarding the affected product.
To effectively comply with this recall, cylinder owners must:
1. Take proper safeguards in identifying and handling the affected cylinders identified in this order.
2. Cease use of all specified cylinders until notified of DOT response to Petition for Review.
3. Arrange to have all propane gas removed from cylinder. This should only be done by qualified persons, trained in handling cylinders in accordance with Federal regulations. (Note: All propane dispensing agents should meet this criteria.) This person must discharge all gas, purge, and remove the valve per the recall.
4. Return the empty, purged, valve-less cylinders, to the manufacturer, freight prepaid, at:
139 Southeast Parkway Court
Franklin, TN 37064
You may also find additional details about the recall in the PHMSA bulletin at:
http://www.phmsa.dot.gov/portal/site/PHMSA/menuitem.ebdc7a8a7e39f2e55cf2031050248a0c/?vgnextoid=7c7384ae997be310VgnVCM100000d2c97898RCRD&vgnextchannel=d248724dd7d6c010VgnVCM10000080e8a8c0RCRD&vgnextfmt=print
  • Thanks for the notification. I've had good luck with these cylinders, so this isn't good news.
  • Just to add, the company has filed bankruptcy, and from what I've read has already stopped funding the shipping. There is no customer reimbursement, either, so those that bought these are out the cost of the cylinder and the propane, and the shipping.
