Roundtwo-40's avatar
Roundtwo-40
Recall on my Jayco door lock
So I got a recall notice on my Jayco TT for the FIC door lock having a problem breaking and locking the occupants inside. My problem is the key does not match, mine is a Baeur make not the square HF keys shown, anyone else have this issue?
  • My key was not on their recall list but I can pull the key out in the 9 o'clock position so I sent my info to them and have them send me a new cylinder and keys...
    The replacement process takes less than 30 seconds when you replace the cylinder...watch the video they provide you on their website
  • Just because you got a notice does not mean that your lock has been recalled.
    They are sending notices to anyone that can potentially have this lock installed on their RV.
    Due to the nature of RV manufacturing, they do not know for sure which locks are installed on which units.
    I got my notice, and my lock was NOT a recalled one.
    Read and follow the directions in your notice to see if yours is a recalled one or not.
  • I have the problem with my FIC lock.
    It has been a total pain since I bought it last May.
    My key code does not line up with the recall ones, but still, it exhibits the same symptoms
    It has been a pain to operate since day one. It has never worked right, ever.
    My lock does everything they describe in the recall bulletin.
    I Guess I should email then and see if they will warranty mine.
    My main lock fell out in my hand one day. So now all I use is the deadbolt. But I can pull the key out at the 9 o'clock position.
    Yeah these things are junk.
  • I received the notice today and briefly looke dit over. I just haven't felt like investing the time this evening to determine if we have that lock or not. Since the trailer is "wintering" 225 miles away, even if I was able to determine that we had the issue, I wouldn't be able to do anything about it until I pick her up in another six weeks, or so.
    Vist or join the Jayco Owners' Forum if you are not a member. There are two ongoing threads discussing Fastec deadbolt lock cylinder recalls. To answer your question, I received a recall notice as well. Both deadbolt lock cylinders in the entry doors of our WhiteHawk were manufactured by Bauer; both operate as they should. However, Fastec requests you supply your trailer's information and lock brand on their website's recall page, whether the lock works properly or not, and regardless if it is a Fastec lock or other brand. Supplying the info. helps Fastec Industrial with recall record keeping/compliance for the NHTSA. Fastec Recall Page
