JimK-NY
Jul 01, 2017Explorer II
TxTiger wrote:
Thanks for all the input. With respect to battety life, I'm not sure what voltage pull there is without anything on. I have a small roof top solar panel that keeps the battery charged, but when I put the cover on the camper the gas sensor shows low battery after just a few days.
This is why your battery did not last. You will kill a new one quickly unless you fix this issue. It seems you have a substantial draw on the battery during storage. You will need to disconnect your battery for storage. You can do that at the terminals but for convenience you might want to install a cut off switch.
44,066 PostsLatest Activity: May 13, 2026
