davehultinExplorer IIIAug 16, 2018Recommendations for slide lubrication?Hi forum, What kind of lubrication do you use / recommend for use on a slide mechanism? Thanks, Dave
rbpruExplorer IIAug 17, 2018My slide is a rack and pinion set up. It is covered on the bottom. I do not believe it was intended to be lubed very often.
Related ContentBedroom Slide LubricatingLippert slide lubricationHappijac lubricationAdding power outlets in slide with no wiringBedroom slide lubrication
