jimh406
Jul 06, 2018Explorer III
If you have overloads, extended bump stops will help with sway if you need airbags to level the ride. I use Energy Suspension ones on current but also the SRW I had. 19.5s also helped with sway on the SRW. F450 comes with stock 19.5s.
Do keep the airbags at a minimum.
Finally, consider upgraded sway bar like a Hellwig Big Wig. That depends on if you truck has one or not.
