TxGearhead
Jul 08, 2018Explorer II
Call Torklift and see if they changed the front brackets or if I needed a different bracket because of the model year.
If you do need the same one with the fish wire, you can work around that.
Torklift supplied a 2" long bolt to be fish wired. Before I got the new truck home I bought longer bolts...2 1/2". Then later I checked the Torklift application chart and they spec'ed a different model for my new truck. The longer bolts will give you a better chance of hanging on to the bolt, supporting the bracket, and starting the nut. You really don't want to drop that bolt and the back-up plate inside your frame.
It was a pretty good trick getting the bolt and plate out of the frame when I took the brackets off before trade-in. I think I used a very small pair of pliers to get just a little bite and wiggle the plate then the bolt out.
Update:
I looked at the Torklift application chart. Looks like they have changed the front brackets to the easier to install model!! Congratulations!!
Update:
