JimK-NY
Jul 08, 2018Explorer II
With all the explanations and comments, I have decided to do the Torklift brackets myself. If I can figure out how to move the 7 pin connector I might try that. Otherwise, I will do the pigtail so my camper wiring will make it to the connector behind the wheel well.
If all goes well and the ride is not too bad, I am done. If not, I would try Stableloads. Assuming the overload spring is drilled that sounds easy.
