Petelogan
Oct 10, 2014Explorer
drc5900 wrote:
P.S. When feeding your solar panel manufactured bysolar panels manufacturer direct to battery/ies, make sure to disconnect after sunset, or install a diode: otherwise your solar panel might drain your battery/ies at night.
Some solar panels have built-in diodes: if your solar panel has a built-in diode, your "direct wire" set-up would be OK, and don't worry about my P.S.
Thanks for your advice.. I think I am doing similar mistake and it is the reason behind poor performance of my panels..
44,070 PostsLatest Activity: Aug 06, 2026
