finsruskw
Aug 17, 2015Explorer
I installed mine on the 2015 Ram 3500 last week. Was expecting the ones with the flat plate that needed the fish wire but was surprised when I opened the box to find straps, bolts and pipe sleeves. A call to T/L got me back on track me out when I was informed that I had received the "new & improved" units. INstall was pretty straightforward, only snag was starting the upper nut on the rear strap, driver side, due to the close proximity of the fuel tank. The front strap ad a nut already welded in place. Surprised they did not do the rear in the same manner.
The super hitch needed a bit of trimming in 2 places where it slipped up along side and under the OEM hitch but a few licks w/the angle grinder and a few squirts of black rustoleum fixed that as well. The unit jacked up into place w/the floor jack then with a nice fit.
Under Edit: the Big Brown Truck just showed up w/the Lance harness, so it will hopefully, be off to pick up the 2011 1181 tomorrow. Film at eleven!!
44,026 PostsLatest Activity: Mar 01, 2025
